Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-24-2010, 07:19 AM   #1
Flat dryer vent code??? duct
I am insulating my laundry room and planning my wall and cabinet layouts. I currently have a dryer vent left of a window that sits 42" from an adjacent outer wall, with the dryer directly below the vent. I would like to move the dryer below or slightly right of the window and the washer to the left to accommodate their door swings. Dryer is reversible washer opens left only.
I do have a low profile extendable vent boot right now approx 2" x 8 "x 6' long which allows the dryer to sit close to the wall.
My problem will be as I move the dryer further to the right the window will be in the way of the boot. I do not want to over extend the vent length. I have the ability to frame the boot into the wall if it meets code.
Is there an efficient low profile boot to go 7 feet up the wall right of the window and allow a flat 90 degree no more than 2" profile below my joists without blocking the window.
I need to go up 7 feet, then 4 feet left below joists, then offset and rise betweenjoist to exit the house. Wall and ceiling are unframed. Ceiling will remain open for now.
Chemist1961 is offline   Reply With Quote
Old 10-24-2010, 07:25 AM   #2
Or is there a flat 90 degree turn kit if I run along the floor below the window and tun up behind the washer
Old 10-24-2010, 10:18 AM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
If can't find off the shelf, a local Plumbing & Heating, or a someone with a sheet metal brake & sheers like a gutter & siding guy that can do it on the cheap may be able to manufacture in their shop. Sad thing is, when high schools had Industrial Arts, you could be able to have the teacher do it with a few students as a project.
Old 10-24-2010, 05:49 PM   #4
Moderator
You cannot bury the transition (adjustable boot) ducting in the wall: http://www.hcpdc.com/pdf/Dryer%20Ven...quirements.pdf
Max. 8' of transition ducting in room-- pipe, your boot, flex, etc.
Must terminate 3’ min. from openings into house- operable window, door- 1502.2: http://docs.google.com/viewer?a=v&q=...up65cYgFwMvULw
Gary
Clothes taking longer to dry?
Tags
dryer, duct, exhaust, vent
Dryer vent leaking imhotep Roofing/Siding 7 12-28-2011 04:54 PM
Dryer Vent Leaks Water glennonr General Discussion 9 04-23-2010 08:50 AM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
Dryer vent duct ninghai Plumbing 2 12-30-2009 10:31 AM
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 05:48 PM
