Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-31-2012, 03:34 PM   #1
Fireplace won't start
My firepplace is turned on by a 'wall switch'. Since it's near Nov. 1, I thought I'd try it out. When I turn on the wall switch, the pilot flame turns on, but after that nothing happens. The pilot flame just keeps burning. I know nothing about gas-heating 'technology' and I am very concerned about blowing my home up. Any suggestions? I cleaned the glass (both sides) in March of this year. I don't 'think' I did anything to disrupt the units' operation then. but I didn't test it after cleaning. I moved into this home in 2008 and have had no problems with the fireplace 'til now.
Bleega is offline   Reply With Quote
Old 10-31-2012, 04:50 PM   #2
Does the pilot light turn on when you flip the switch, like you wrote, or does it stay on all the time?
hvac benny is offline   Reply With Quote
Old 10-31-2012, 04:57 PM   #3
Experienced
Jackofall1's Avatar
Hello Bleega, and welcome the best darn DIY'r spot on the internet.
Not seeing what you have and you not knowing what you have, I would strongly suggest calling in a service technician. This is best and safest route I can suggest.
Mark
Old 11-01-2012, 06:40 AM   #4
custom user
I can't imagine why the wall switch would turn on the pilot light. Are you sure it isn't on regardless? And that the gas control is set to ON? They make their own electricity (750mV at best) when the thermopile is properly heated, which holds the main burner valve open when the wall switch completes the circuit. So, no heat=no electricity and the gas valve be closed. At least the ones I'm familiar with. More info you provide the better answers you'll get.
JasperST is offline   Reply With Quote
Old 11-01-2012, 08:46 AM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
agree with Jasper here, there is usualy an on off switch somewhere on the fireplace. You may have hit it when you were cleaning it. and by all means if you are unsure call in a tech.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Can I mount my flatscreen inside the fireplace opening? minpin Home Theater 15 03-04-2013 02:03 AM
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 10:56 PM
Stone Veneer (ledgestone) fireplace remodel questions Augy Remodeling 7 01-11-2012 08:20 PM
Gas fireplace question - Who will save me? Pig General Discussion 12 08-10-2010 10:34 AM
