-   -   Fireplace won't start (http://www.diychatroom.com/f47/fireplace-wont-start-161745/)
Bleega 10-31-2012 03:34 PM
My firepplace is turned on by a 'wall switch'. Since it's near Nov. 1, I thought I'd try it out. When I turn on the wall switch, the pilot flame turns on, but after that nothing happens. The pilot flame just keeps burning. I know nothing about gas-heating 'technology' and I am very concerned about blowing my home up. Any suggestions? I cleaned the glass (both sides) in March of this year. I don't 'think' I did anything to disrupt the units' operation then. but I didn't test it after cleaning. I moved into this home in 2008 and have had no problems with the fireplace 'til now.
hvac benny 10-31-2012 04:50 PM
Does the pilot light turn on when you flip the switch, like you wrote, or does it stay on all the time?
Jackofall1 10-31-2012 04:57 PM
Hello Bleega, and welcome the best darn DIY'r spot on the internet.
Not seeing what you have and you not knowing what you have, I would strongly suggest calling in a service technician. This is best and safest route I can suggest.
Mark
JasperST 11-01-2012 06:40 AM
I can't imagine why the wall switch would turn on the pilot light. Are you sure it isn't on regardless? And that the gas control is set to ON? They make their own electricity (750mV at best) when the thermopile is properly heated, which holds the main burner valve open when the wall switch completes the circuit. So, no heat=no electricity and the gas valve be closed. At least the ones I'm familiar with. More info you provide the better answers you'll get.
hardwareman 11-01-2012 08:46 AM
agree with Jasper here, there is usualy an on off switch somewhere on the fireplace. You may have hit it when you were cleaning it. and by all means if you are unsure call in a tech.
