Fireplace Mantle - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-11-2014, 03:05 PM   #16
Rewards Points: 326
DONE!!!!!!
cut through the caulking, and the mantle pretty much moved with ease. Had to break the hidden wood bar a bit, thats ok, it probably only supports any major weight on the top. Luckily i just mounted my tv.
once removed, cleaned up the area and bam....
1. stop pipe was center in the hole!
2. cleaned area
3. applied High Temp silicone (Red) into the 1in gap
4. seal around the entire pipe
5. happy wife
6. put the mantle back (unfinished)
7. gotta caulk around the mantle to finish
thanx everyone for your help... now moving on to next project
Amitabh is offline   Reply With Quote
The Following User Says Thank You to Amitabh For This Useful Post:
jmon (01-11-2014)
Old 01-11-2014, 03:11 PM   #17
Rewards Points: 342
Great job. You'll be warmer and save money on your utility bill to. Glad everything works the way you want now.
jmon is offline   Reply With Quote
Making a Mantle for a Stone Fireplace. Two Knots Building & Construction 10 10-24-2013 05:53 PM
fireplace mantle MKGBC Remodeling 2 08-26-2010 11:38 PM
fireplace mantle and trim board connieriv Interior Decorating 3 01-04-2009 10:33 AM
Fireplace Mantle need help with color and technique Staticman2 Interior Decorating 4 12-11-2008 02:05 PM
Question about wood mantle on stone fireplace Daggerhart Remodeling 2 06-15-2008 04:16 PM
