Fasco Blower Inducer 7062-3136 - Appliances - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 08:55 AM   #1
Post
Fasco blower inducer 7062-3136
Hi all, I have a problem with the above inducer blower and even though some of the fan blades are broken (3), the motor seems to work fine but no pilot light, hence no heat. Do I need to change the whole inducer assembly of is there another solution? Thanks. If I have to replace the whole, any suggestion of where to find an OEM that is not going make to poor? Thanks again.
Aziza007 is offline   Reply With Quote
Old 12-10-2010, 07:40 AM   #2
Rewards Points: 516
Post these type issues under HVAC section for better response.
I have been where you are, twice.
Best advice: Use search feature above. Search on 8710-4358. It will get you to recent post with lots of good info. "Furnace will not stay on".
Good luck. If you are handy, you can fix.
Latest Fasco link: http://www.fasco.com/replacem.asp
Look under blowers
diyorpay is offline   Reply With Quote
The Following User Says Thank You to diyorpay For This Useful Post:
Aziza007 (12-10-2010)
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Replacing Fasco 7062-3136 draft inducer blower on my Bryant Gas Furnace thalweg76 HVAC 0 02-20-2010 03:35 PM
Replacement impeller and clip for Heil exhaust inducer blower iixeb HVAC 2 01-09-2009 08:36 PM
Install Fasco Inducer Model A242 morrelld97 HVAC 1 10-03-2007 07:40 PM
Replacement Inducer Blower caseywa HVAC 18 11-27-2006 03:42 PM
