Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-27-2012, 01:57 PM   #1
fan motor
I have a vintage W T Grant Thermostat reversable 3 speed window fan, that was in the attic. Worked great for 50 yrs. recently somehow a wire was sliced by the blades. All the wires were sodered in the motor and no motor information. Believe it is 1/6 hp with 1/2 inch shaft. I need to replace the motor and don't know what size to go with. It doesn't need to be reversable or variable speed, but does need the thermostat
daschimming is offline   Reply With Quote
Old 08-27-2012, 06:13 PM   #2
Bombastic Idiot
notmrjohn's Avatar
fan motor
Can't you splice the wire? Grainger is a good source for motors. Especially if there's one near you and you can take the motor with you. There paper catalogue is easier to use than online, but here's a starting place
http://www.grainger.com/Grainger/wwg...h=true&sst=All
notmrjohn is offline   Reply With Quote
How to replace condensor fan motor? twags HVAC 41 09-13-2012 07:05 PM
Condenser Fan Motor stopping after 10-15 minutes, but will restart justplumducky HVAC 14 07-14-2012 03:36 PM
Old Rheem Air Blower Motor Wiring Problem CompoundNetwork HVAC 3 11-20-2011 04:51 PM
Air Handler Motor Wiring brando1118 HVAC 13 06-18-2010 12:42 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 07:30 PM
