Extra Support For Over Range Microwave - Appliances - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 12:03 AM   #1
Question
Extra support for over range microwave
Hello,
Husband and I installed a new over range microwave today, and 2 of the 3 screws holding it to the above shelf stripped (the threading not the screw heads). The shelves on either side are higher than the bottom of the microwave (unfortunately) which makes it trickier to add extra support in the front. Just wondering if anyone had any ideas on how to give some extra support in the front? Thought about maybe some Z brackets or strapping, just concerned about the esthetics of that.
Beccablue is offline   Reply With Quote
Old 04-21-2013, 03:24 AM   #2
What about just getting new screws?! Or retapping the screw holes?
wireless is offline   Reply With Quote
Old 04-21-2013, 09:33 AM   #3
Rewards Points: 12,824
Got a picture?
Old 04-21-2013, 09:43 AM   #4
Rewards Points: 142
this ^
Fix'n it is offline   Reply With Quote
Old 04-21-2013, 10:21 AM   #5
Bill Kearney
Rewards Points: 1,174
Most over-the-range microwaves come with a wall bracket that attaches to the wall behind it. That and bolts that come down from a cabinet/shelf above. They don't usually use screws for the top connection. Are you saying the threads inside the cabinet of the microwave got stripped? That's bad, but they could be re-tapped with somewhat larger threads and new bolts used. Or are you talking about how the bracket was attached to the rear wall?
What specific make/model microwave is this?
wkearney99 is offline   Reply With Quote
Old 04-21-2013, 10:50 AM   #6
Thumbs up
I am talking about the bolts coming down from the cabinet. Microwave is an LG lmv2015. Actually, just got them out and it was just the bolts that stripped, not the internal threads (thankfully). We replaced them with bolts from the previous microwave which matched the threading closely enough. Thanks for all your help guys!
Extra Floor Joist framing and support needed under kitchen island? dvaupel Building & Construction 4 09-27-2012 03:38 PM
Oven Range Microwave lstamour Appliances 1 11-30-2011 04:13 PM
Over the range microwave and offsetting 12 deep wall cabinets samotlietuvis Remodeling 4 09-24-2011 02:43 PM
removing an over the range microwave southcreek Appliances 1 07-03-2011 12:40 PM
extra support of the load bearing wall redcloud Building & Construction 11 06-22-2009 05:35 PM
