Extactor Fan Wiring - Appliances - DIY Chatroom Home Improvement Forum
Old 11-26-2006, 11:42 AM   #1
Extactor fan wiring
Hi all, hope you can help me, I removed an extractor fan to have it cleaned. I and never noticed at the time that it has 3 wires from the motor, brown, blue, and black. (plus the earth) There is also a capacitor that needs to be reconnected. The incoming supply is single phase, live and neutral but comes from a variable speed controller.
Any pointers would be appreciated.
camman is offline   Reply With Quote
Old 11-26-2006, 12:17 PM   #2
World famous jerk.
So you just tore it all apart, without regard to where the conductors were connected? I say you got the fan you deserve.
If you care to post the manufacturer and model number, maybe we can help some more.
mdshunk is offline   Reply With Quote
Old 11-26-2006, 12:36 PM   #3
Thanks for your reply, I never tore it apart! Just disconnected it without relising it has 3 conductors; I will try to locate some information of the motor, and post what I find.
Tanks again.
Old 11-26-2006, 03:22 PM   #4
jeff1's Avatar
Hi,
I know crap about extractors...but there may be a wire diagram in/on the unit itself...even some motors have a diagram right on the motor itself.
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 11-26-2006, 03:38 PM   #5
Thanks Jeff, i will check it out at the same time as i look for model number ect, i will let you know how i get on.
Regards
Dave
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
