Extactor fan wiring
Hi all, hope you can help me, I removed an extractor fan to have it cleaned. I and never noticed at the time that it has 3 wires from the motor, brown, blue, and black. (plus the earth) There is also a capacitor that needs to be reconnected. The incoming supply is single phase, live and neutral but comes from a variable speed controller.
Any pointers would be appreciated. |
So you just tore it all apart, without regard to where the conductors were connected? I say you got the fan you deserve.
If you care to post the manufacturer and model number, maybe we can help some more. |
Thanks for your reply, I never tore it apart! Just disconnected it without relising it has 3 conductors; I will try to locate some information of the motor, and post what I find.
Tanks again. |
Hi,
I know crap about extractors...but there may be a wire diagram in/on the unit itself...even some motors have a diagram right on the motor itself. jeff. |
Thanks Jeff, i will check it out at the same time as i look for model number ect, i will let you know how i get on.
Regards Dave |
| All times are GMT -4. The time now is 08:43 AM. |
