Exhaust Fan on Built-In Microwave
We're renovating our old kitchen and are getting a built-in microwave over the range. My wife wants the exhaust to go to the outside to get rid of smells and steam. I would like a filtered one to prevent outside air from coming in.
If we go with venting outside, can it be sealed with a draft preventer? If we go with a filter, would it reduce smells and steam? |
Vent it outside. The vent kit will have a backdraft damper in the outside wall hood.
You'll be much happier with your indoor air quality by venting outdoors. The carbon filter used for recirculating vents really don't do much as far as reducing odors. |
If you vent it outside, how will you know when you are burning the popcorn?
Good advice. To vent outside, what exterior parts do I need? What comes with the microwave?
My electrician needs to know how high the fan is and where to mount the box for the microwave's dedicated circuit. Is it a separate cicuit for the fan? |
One circuit powers the microwave and fan. Usually 20 amp, check the directions.
Is this a hardwired microhood? Most have a cord/plug arrangement. In that case the outlet normally goes into the cabinet over the microwave. A hole is drilled and the cable runs into the cabinet. Outside venting is the best way to go. |
Good advice, everybody.
What should I look for in a new microwave? |
Compare power output. 950-1100 watts or so is pretty much standard. Watch how they vent. It pays to look the model up online and read the installation and venting instructions before you buy it. Most will convert from recirculating to rear or top exhaust. Good luck. |
| All times are GMT -4. The time now is 11:25 PM. |
