Electricstove - Appliances - DIY Chatroom Home Improvement Forum
Old 07-23-2011, 06:07 PM   #1
electricstove
Oven and digital display don't work. Burners all work well. Breakers are oK Is there a fuse in the stove itself that broke?
jdeegan is offline   Reply With Quote
Old 07-23-2011, 06:33 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Some stoves probably do have fuses, I'd open up the back and check... ensure it's unplugged!
Lot of stoves have power outlets on top, I would imagine there is a 15 amp fuse for those, so maybe the same fuse also feeds the clock portion.
Old 07-23-2011, 07:32 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
as far as I know there are no stoves that use a fuse to protect the clock, you'd have to confirm clock is getting 110 volts. If so then the clock is bad.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
