Electric Water Heater(old School) - Appliances - DIY Chatroom Home Improvement Forum
Old 05-15-2012, 12:41 PM   #1
electric water heater(old school)
My My electric water heater's wiring for the first element is fine, but when my friend checked the second element, he said the wiring was fried. My question is, is it worth it to fix and how complicated is it to fix?
vicki55pinky is offline   Reply With Quote
Old 05-15-2012, 01:48 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by vicki55pinky View Post
...is it worth it to fix and how complicated is it to fix?
Depending on what "fried" means...
but anyone competent enough to make this "diagnosis" should be able to do the repair in less time than it takes to explain it.
Changing out the heating elements (if needed) is where it can get tricky.
Old 05-16-2012, 09:10 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
I would have to agree with that, take 2 minutes and pull 2 new wires.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-17-2012, 08:12 AM   #4
Well wanna fix the problem then pull those two wires and add up two new.
Well as the question of the difficult then I suggest you that you must install those wire from your friend who have some how know about it...
nobeel25 is offline   Reply With Quote
Old 05-17-2012, 09:45 AM   #5
DIY or die !
Rewards Points: 77
dude, do yourself a favor and get a TANKLESS !
lewisthepilgrim is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Not Enough Hot water in the shower from a 40 Gallon Electric Hot Water Heater. rcake Plumbing 10 06-10-2011 01:20 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
