Electric Stove Trouble - Appliances - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 02:01 PM   #1
electric stove trouble
oven working great but having problems heating with stove elements. Could this be the breaker? How to check the breaker?
Dylan. is offline   Reply With Quote
Old 07-26-2010, 02:37 PM   #2
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Is this a new stove or replacement?
How big of a breaker is it on?
What brand and model stove is it?
Big N8 is offline   Reply With Quote
Old 07-26-2010, 08:11 PM   #3
If the oven is working, there is nothing wrong with the breaker. Both the oven and the cook top get their power from the same breaker.
What kind of problems are you having with the elements?
yarddawg is offline   Reply With Quote
Old 07-27-2010, 02:17 AM   #4
Rewards Points: 150
Better check on the connection wire or something underneath the electric stove. It may somehow be broken or disconnected.
MagicalHome is offline   Reply With Quote
Old 07-27-2010, 03:19 PM   #5
Rewards Points: 104
Very likely a burned out element. Smooth top or conventional? On our last conventional, "we" replaced several over 20 + years, although after I did the first one, she did the rest herself. Our smooth top is a bit more work, but still manageable, although I have heard that some of the smooth tops are best left for the professionals to deal with.
Old 07-27-2010, 03:42 PM   #6
Rewards Points: 590
Elements break down with use. Eventually, they heat very unevenly and even smell bad. If you're burning stuff or cooking slowly, replace them. Splurge on the ones with more turns, if possible. They are expensive but the performance will be better and for a longer time.
operagost is offline   Reply With Quote
Old 07-27-2010, 04:34 PM   #7
Handyman
Rewards Points: 512
No sure of the stove you have but typically you can raise the top half of the back and you will see fuses..20amps and 30 amps Check the 20 amps and replace
canadaclub is offline   Reply With Quote
changing old 1800 model stove from electric to gas Rangerwife731 Appliances 2 09-23-2009 07:58 PM
re-wiring an old electric stove user62257 Electrical 3 09-15-2009 11:44 AM
Electric Boiler Merged w/ Wood Stove Radiator westphaltyler HVAC 1 03-23-2009 10:44 PM
Converting from Gas to Electric Stove Chloe Appliances 1 06-14-2008 03:06 PM
Electric Stove Help tempmeo Electrical 7 06-05-2006 07:18 PM
