Electric Pressure Cooker Power Cord Socket Melted - Appliances - DIY Chatroom Home Improvement Forum
Old 05-31-2014, 10:21 AM   #1
Rewards Points: 1,584
Electric pressure cooker power cord socket melted
I have a Cusinart electric pressure cooker. After dinner yesterday I removed the power cord from the wall receptacle, and the other end of the cord which is a female plugs into the cooker's bottom. That end has a melted slot.
Does this mean I need a replacement cord? Or does it mean there is something wrong with the cooker itself that caused this problem?
miamicuse is offline   Reply With Quote
Old 05-31-2014, 10:38 AM   #2
Like he male end on the pressure cookers is damaged as well. This looks like some arcing occurred the last time it was used. Either the cod was not seated tightly on the connection or there was direr in the end of the cord that caused an loose connection. Either way, you need a new cord and you should inspect the male end on the cooker for damage. If it's superficial it can be cleans up but it may have arced bad enough that you will not get a tight connection and the problem will repeat itself. You may need to replace the male connectors on the appliance
jimn01 is offline   Reply With Quote
Old 05-31-2014, 11:47 AM   #3
Rewards Points: 444
It may also be wise to inspect or replace the outlet, wire connection and check the appliance for amp draw.
Electric Cord on Kitchen Garbage Disposal Sycamore Inn Electrical 18 08-24-2012 08:53 PM
Electric Company Saying I use More Power Than I Do CarpeMofo Electrical 18 08-23-2012 11:46 PM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
Light cord to screw in socket adapter? Charger Electrical 11 05-02-2010 07:04 PM
Electric Cooker Tofu Electrical 1 01-08-2008 06:44 PM
