Electric Or Gas Or Both? - Appliances - DIY Chatroom Home Improvement Forum
Old 02-20-2009, 05:41 PM   #1
Electric or Gas or Both?
I just moved into my new house (hurray!) and have someone who is willing to give me their electric dryer till I can get my own. I was told that I can probably have the choice of either gas or electric because of my hookup.
Well, I am absolutely clueless about this, and would hate to haul the appliance over here only to find out it doesn't work with my connections.
So here is what I got:
There is a big 3 prong connection that says "Leviton 30A-125/250V" on it and there is a pipe connected at the bottom of the wall with a shut-off valve on it (I assume the gas hookup?)
So if I have the big 3 prong connection at 250V, would that be sufficient to handle the electric dryer?
Thanks.
hammermonkey is offline   Reply With Quote
Old 02-20-2009, 05:46 PM   #2
You need to know the rating of the dryer
My dryer is rated for 30a
Gas may be less expensive in the long run
Depends upon cost of each where you are
Old 02-20-2009, 05:53 PM   #3
Crazy, but lovable
flyboy2610's Avatar
Yup. That sounds like the hookup for the dryer. Gas or electric is your choice. I've never had a gas dryer. I like my electric one fine.
flyboy2610 is offline   Reply With Quote
Old 02-20-2009, 05:59 PM   #4
Remodeling Contractor
Electric is fine for the dryer. Are you using gas anywhere else? If the electric one is free and you have the connection.. then this is the way to go
Old 02-20-2009, 06:40 PM   #5
I am going with the free electric dryer till I can afford to buy a gas dryer. I use gas for also my water heater and heating system.
OK. Thank you everyone for the answers. It looks like I will be hauling a dryer over to my house this weekend.
Converting duplex to single family--what to do with electric services? zamoti Electrical 32 01-29-2009 04:16 PM
Connecting electric motor to swtich and marine battery Lawnplugger Electrical 5 09-13-2008 02:11 PM
Electric Heat pump in New England? jzinckgra HVAC 7 05-22-2008 03:02 PM
Electric Line Under Ground Crazy Legs Electrical 9 04-15-2008 11:07 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 12:40 PM
