Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-16-2012, 12:20 AM   #1
crankcase's Avatar
Electric dryer wont start Kitchen Aid model KEYS700GQO
My thermal fuse is open and I am trying to get one load dry tonight for the wife before I go get a replacement in the morning. There was a dryer sheet stuck on the grille which took out the fuse again I tried to substutite a 10A mini auto fuse which blew a split second after I pushed the start button, however the motor did try to start. I think I could do it with a larger fuse and I think it would work however The wires are 18AWG and that's about the max fuse size I want to try. Of course my electrical schematic is missing from the back side of the control panel. My next size fuse is a 15A and I know that is sized for 14AWG wire not 18AWG. I think I'm stuck till morning, any suggestions?
crankcase is offline   Reply With Quote
Old 05-16-2012, 09:05 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
if you are going to put in an automotive fuse, you may as well 'jumper' it. Both will provide the same amount of protection. None. Just wait and get the proper fuse.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-17-2012, 08:09 AM   #3
There could be a problem in jumper which I believe...
Well there could be also problem in the button it don't get current properly or it spark after it start..
Anyhow I'll suggest you that check it to any expert...
nobeel25 is offline   Reply With Quote
Old 05-17-2012, 09:48 AM   #4
DIY or die !
The thermal fuse blew for a reason. You have an obstruction....probably not your dryer sheet. Go buy a vent cleaning brush attachment for your drill. Run it through the vent from the outside, all the way back to the dryer. NEVER reverse the drill(you might loose your brush). Repeat quite a few times untill all the lint is out of the vent. Start the dryer and check for airflow outside @ the vent. It should be QUITE STRONG !
Also, How long is your vent run ??
lewisthepilgrim is offline   Reply With Quote
Old 05-18-2012, 01:43 AM   #5
Moderator
Good advice! Could also be the transition box near the lint screen to ducting adapter, may need a good cleaning where the brush won't go...
Gary
Clothes taking longer to dry?
Rewiring Electric Dryer Plug michaelson Electrical 25 03-23-2012 07:30 PM
Electric range in dryer outlet Greenlevel Electrical 5 02-03-2011 06:20 PM
GE Electric Dryer won't shut off in auto/high heat mode jktbnelson Appliances 7 01-15-2011 08:39 PM
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 07:18 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
