Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-16-2007, 09:15 AM   #1
mt232's Avatar
Electric dryer stops
Any ideas why an electric dryer would just stop after a few minutes? then work again later?
Is this fixable?
mt232 is offline   Reply With Quote
Old 05-16-2007, 07:41 PM   #2
Diesel Fitter
No and no!
mikemy6 is offline   Reply With Quote
Old 05-16-2007, 07:57 PM   #3
It could be a loose wire connection at the appliance, panelboard, or even on the electrical utility end. But then again it could just be an improperly balanced machine that is causing the door to open and therefore opening a set of contacts and interupting the circuit. Could also be a bad cord.
ElectrianRon is offline   Reply With Quote
Old 05-16-2007, 08:11 PM   #4
Could be a thermal safety switch type thing. Somethings getting too hot (motor or element) and opening the switch. As it cools down the dryer can be restarted, but then it overheats again.
I'd say if the timing is very consistent (always runs for the same number of minutes before stopping) then it's likely to be an overheating problem.
If the failure is irregular and intermitent, then it's possible it's a wiring problem.
NateHanson is offline   Reply With Quote
Old 05-17-2007, 10:03 AM   #5
mt232's Avatar
Thanks, from what I read, the thermal safety switch seems to be the issue, the door is sound, doesn't open, wires are stable and the timing is very consistant.
Old 05-23-2007, 10:57 AM   #6
I would defintely check the high limit stat and check for a shorted elelment causing an overheating situation. Hope it is not a burnt spot on the contacts in the timer. Acuall, I would maybe check all the stats. Usually when a high limit stat goes, it is not resettable. Another thing to check is the venting in the wall and in the dryer itself. Make sure the vent fan is turning on the motor and there is no blockage in the venting system of the dryer. Might be surprised at the lint that can find its way inside the cabinet.
Old 05-24-2007, 11:21 AM   #7
mt232's Avatar
Actually it was the thermostat. From advice here, I first opened the back and found it was quite clean with no lint buildup or stray socks blocking anything......but there was a few nails....gotta empty my pockets better.
So for 20.00 I took a chance on the logical replacing of the thermostat. It has run about 5 loads successfully
Old 05-25-2007, 03:24 PM   #8
Good to hear.
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 05:33 PM
Problem with ELECTRIC DRYER plugs SpaceCrawler Appliances 6 06-03-2007 11:21 AM
electric dryer heating element gooch Appliances 2 03-27-2007 10:31 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
Is this even possible?? Serendipity Plumbing 5 04-28-2006 10:45 AM
