Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-25-2007, 09:12 PM   #1
electric dryer heating element
i have stackable washer/dryer. the dryer part doesnt seem to be heating up enough. i can put the dryer on a 90 minute cycle and the clothes wont even be close to being dry. i dont know anything about dryers but the element has continuity through it. my question is can an element be bad even if it has continuity through it? i have bought a new limit switch, could this fix my problem? i would like to get some advice from someone who has a better idea than i do before i put everything back together. any suggestions would be appreciated. thanks.
-gooch
gooch is offline   Reply With Quote
Old 03-26-2007, 05:27 PM   #2
hey,
I had the same sort of problem last year. I replaced the heating element and the dryer works perfectly. I believe there was NOT continuity through my element, but there was 240v present at the connectors. You may want to pull the element out and inspect it by hand.
Try carefully measuring the voltage at the terminals while it is running to make sure it is getting any voltage.
Is there any heat at all? How's the airflow? Try disconnecting the exhaust vent from the output to see if it gets any better.
elementx440 is offline   Reply With Quote
Old 03-27-2007, 10:31 PM   #3
i replaced the thermostat (limit switch?) plus i think my exhaust vent was smashed behind the dryer so it wasnt getting much air flow. seems to work fine now except now the washing machine part leaks water. im sure i just need to tighten a fitting though. thanks for the help.
-gooch
More On This Topic
Hi! My name is Leslie Moselle and I am from Tampa, Florida and on behalf of Expert Village, this is how to do laundry. The process for drying your towels and rugs is the same no matter what color they are. So I am going to go ahead and just let you know... Read More »
Hi! My name is Leslie Moselle and I am from Tampa, Florida and on behalf of Expert Village, this is how to do laundry. Delicate clothes are probably the most important thing to be careful with when drying. There are two options for drying your delicate... Read More »
Alright well next to our washing machine we have our dryer and that way you don't have a lot of movement between the washer and dryer. It saves me time on my feet, a lot of soreness and stuff like that. The reason why dry cleaners have such large... Read More »
Hi, my name is Leslie Moselle. I'm from Tampa, Florida and on behalf of Expert Village this is how to do laundry. First thing you want to do when doing your laundry is to first familiarized yourself with the settings of your washer and dryer. All washers... Read More »
Okay, so we have finished our design. Basically, we're going to let it dry for a good hour or so. Read the directions because every paint is slightly different. In general, what it's going to tell you is to turn the jeans inside out and you're going to... Read More »
Slate Floor Electric Underfloor Heating Lottie Flooring 5 12-23-2009 11:04 AM
Electric Dryer wiring/plug question SpaceCrawler Electrical 7 08-26-2008 05:33 PM
Problem with ELECTRIC DRYER plugs SpaceCrawler Appliances 6 06-03-2007 11:21 AM
Electric dryer stops mt232 Appliances 7 05-25-2007 03:24 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
