Ele Slide In Stove - Appliances - DIY Chatroom Home Improvement Forum
Old 10-01-2013, 02:05 PM   #1
Rewards Points: 20
Ele slide in stove
Oven was on preheat and pow, the 100 amp main breaker tripped. The upper top elements still work after resetting the breaker. The preheat controls still light up, but get no heat from the bake element.
When I push either the bake or broil control on, there is no voltage coming out of the terminals on the back of the control timer.
I disconnected the leads to the bake element and get a 21.5 ohm reading.
Any suggestions?
model # is FEF352ASF
Thanks Emmy
emmy is offline   Reply With Quote
Fridaire ele slide in stove emmy Appliances 0 09-30-2013 09:25 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 04:54 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 09:28 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 09:30 PM
