Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-05-2012, 06:57 AM   #1
verytryinglol
ED56-U assembly problem . help please
I have an ED56 F&P dryer . I have it apart atm , and have replaced the heating element . but something is not right when I put it back together . the 2 pulleys arent sitting close to the shaft of the motor , which the belt runs through . I need to find a website that shoes me some internal , rear view diagrams/photos so I can see where I have gone wrong , Any assistance/info would be appreciated . Thanks Aleish
Blondi is offline   Reply With Quote
Old 07-05-2012, 09:20 AM   #2
Super Moderator
F&P--? Please give the full proper name and your country--
USA Canada UK Australia Germany South Africa?
Old 07-05-2012, 09:58 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
good luck with any Fisher Pykel help, they are one of the worst with any type of "free help". Maybe if you could post a photo here of what your problem is I could probably walk you through it.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-05-2012, 10:06 AM   #4
verytryinglol
Sorry for only posting minimal information , F&P ... Fisher and Paykel and I'm in Australia . I have a couple of photos from before I dismantled the unit .
I will go and get some new photos of the way the unit looks now . I'll be back shortly
Old 07-05-2012, 10:54 AM   #5
verytryinglol
Ok Before and after shots of belt drive . notice in the after shots how far down the motor/shaft is sitting , Ive tried various things I thought It might have been , Im pretty mechanically minded . but this one has got me .... hope you can help :P
ED56-U assembly problem . help please-pulley-config-before-disassembly.jpg   ED56-U assembly problem . help please-pulley-config-also-before-disassembly.jpg   ED56-U assembly problem . help please-pulley-config-after-assembly.jpg   ED56-U assembly problem . help please-after.jpg   ED56-U assembly problem . help please-also-after.jpg
Problem with toilet (vent problem?) branch155 Plumbing 24 03-09-2012 10:37 AM
Boiler Question regarding Pilot Relite Control & Ignition Electrode Assembly stevepatts HVAC 0 02-22-2012 09:42 PM
flame sensor problem junkcollector HVAC 1 12-09-2009 09:19 AM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
