Dtv Converter Has Noise On All Channels - Appliances - DIY Chatroom Home Improvement Forum
Old 02-11-2009, 03:55 PM   #1
the Musigician
DangerMouse's Avatar
dtv converter has noise on all channels
not only does it have hiss/buzzn every channel, even ones with 100% signal, the volume on the converter does not do ANYthing all the way up or down, and if i turn the dumb thing off, it has to rescan all the channels again for ten minutes! any ideas on the noise? i googled it and i see i'm not the only one, and it's not just my brand of box either.
DM
Old 02-11-2009, 06:01 PM   #2
Rewards Points: 1,512
You may need better grounding. Get a length of wire, say, 16 gauge, bare is OK, to connect your converter box, your TV, your surround sound amplifier if any, etc. to each other and connect the far end to a known ground. Generally a good way to make each connection is to use a screw that holds the converter box cabinet together, holds the TV cabinet together, etc. The screw that holds the cover on a wall electrical outlet, or a pipe inside a baseboard radiator should be an acceptable ground.
How is the converter connected to the TV (what cables)?
Old 02-11-2009, 07:03 PM   #3
the Musigician
coax that came with it
DM
Old 03-06-2009, 08:09 AM   #4
the Musigician
OKAYYYY!! i figured out how to make it work! all channels perfect now. (never DID find any help with google)
what i did was (please send $20.00 US for answer) hehehehe, oh wait, that was another thread....
i swapped out the crappy coax and used good quality RCA jacks for audio and video. turned TV to AUX1 and scanned, all's well now, no more hiss and buzz in the audio! i hope this answer will help others that will likely have the same problem!
DM
New Rheem 90+ is making a strange noise. Draft inducer? shinkansen HVAC 1 01-09-2009 08:38 AM
power line noise sciguy125 Electrical 5 12-02-2007 01:39 PM
water heater noise boman47k Plumbing 5 11-28-2007 06:31 AM
GE side-by-side making a whining noise jkrodger Appliances 2 09-11-2007 02:45 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 04:33 PM
