Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-06-2009, 02:44 PM   #1
Dryer won't turn itself off
MY DRYER WORKS, BUT WON'T TURN OFF UNLESS I TURN IT OFF. TIMER DIAL DOES NOT MOVE DURING DRYING CYCLE. WHAT MIGHT BE WRONG AND WHAT KIND OF PART WOULD I NEED TO FIX IT?
THANK YOU FOR YOUR TIME, BETH
bethlex123 is offline   Reply With Quote
Old 03-06-2009, 08:30 PM   #2
Crazy, but lovable
flyboy2610's Avatar
Sounds like your timer is finished for good.
flyboy2610 is offline   Reply With Quote
Old 03-07-2009, 02:24 PM   #3
I met a guy who rebuilds timers and says there is quite a business there. I would try the dryer on auto cycle as well but sounds like a timer
Chemist1961 is offline   Reply With Quote
Old 03-26-2009, 10:33 PM   #4
If you are using your dryer on a automatic cycle the timer will not turn if the dryer is not heating so your heating element may be bad. GE dryers have two heating elements if one is bad the timer will not turn but you will still feel heat in the tub. Like they said it can be the timer but they don’t go bad often. One way you can check this it to try using a timed cycle if the timer still won’t cut off the timer is bad.
Last edited by Scuba_Dave; 09-30-2010 at 12:51 PM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
Dryer vent ponch37300 General Discussion 10 01-21-2009 05:26 PM
Pilot light button on furnace won't turn whydonchathen HVAC 5 10-06-2008 12:03 AM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 09:16 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 11:45 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 11:03 AM
