Dryer Won't Shut Off But Has No Heat - Appliances - DIY Chatroom Home Improvement Forum
Old 10-03-2007, 07:28 PM   #1
Dryer won't shut off but has no heat
I'm posting this for my sister. She has a whirlpool dryer that won't shut off on its own. It also has no heat coming out. It's not that old - couple of years maybe. Ideas?
Keyo77 is offline   Reply With Quote
Old 10-04-2007, 06:56 PM   #2
gas or electric?
redline is offline   Reply With Quote
Old 10-05-2007, 09:11 AM   #3
Electric.
Old 10-05-2007, 08:02 PM   #4
have you tried pressing the heater reset button? make sure the filter is clean.....
fridgeman is offline   Reply With Quote
Old 10-05-2007, 08:19 PM   #5
Custom Cabinet Maker
check the timer
skymaster is offline   Reply With Quote
Old 10-06-2007, 08:48 AM   #6
Where can she find that button?
Old 10-06-2007, 08:49 AM   #7
Originally Posted by skymaster View Post
check the timer
That was my first thought too, but would that have anything to do with the no heat issue? What should she look for if it is the timer?
Old 10-06-2007, 10:46 AM   #8
Timer runs the whole machine, it does the cycles which in turn call for and turn off heat, ect. Since this is a fairly new machine, I would look at the heating element as a last point. Might be worth just calling a repairman.
Old 10-07-2007, 02:42 AM   #9
Most units have a heater safety button, ie if the filter is 100 % clogged it will trip the button and not burn the element out.....If you have not heat, this will be your problem for sure...not sure where it is on your unit, myne is where the dorr opens...could be internal.?
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Dryer on the fritz.. wiring problem? cisco10 Electrical 17 11-19-2009 01:26 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 08:57 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
