Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-17-2012, 11:00 AM   #1
dryer will not shut off
I have a kenmore dryer that will not shut off when the cloths are done. It just keeps going and the dryer and cloths get real hot. Does anybody have a idea what would cause this?
jerry1967 is offline   Reply With Quote
Old 11-17-2012, 11:22 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Timer is the first to check. Repairclinic.com is where I have gotten parts from for appliances in my house.
Last part was a handle for our Dishwasher, and even though I ordered it at 5:30 at night, got it next day.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 11-17-2012, 09:56 PM   #3
Running on timed cycle? The moisture sensor on mine is malfunctioning, so we just run it on the timed cycle. If not, it will just run and run.
If it does not stop when on timed cycle, I would suspect the timer or timer motor.
Old 11-18-2012, 04:23 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
need to know what cycle you are using. Time dry, sensor dry or auto dry. If it is time dry then you have a bad timer, if sensor dry the you either have a bad sensor or a bad timer if auto dry then you either have a bad timer or possibly a restricted vent
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-23-2012, 07:51 PM   #5
I installed a new push to start switch, also a new timer but I still have the problem.
The dryer will not stop in the time dry, sensor dry or auto dry.
Old 11-24-2012, 06:11 PM   #6
#1 HAWKEYE FAN
model# ?
Old 11-24-2012, 06:21 PM   #7
Model# 11063932101
What does the power relay do?
Old 11-26-2012, 11:28 PM   #8
#1 HAWKEYE FAN
does it have an electronic circuit board up by the timer?
Old 11-26-2012, 11:29 PM   #9
#1 HAWKEYE FAN
Originally Posted by jerry1967 View Post
Model# 11063932101
the relay is only used to send power to the heat element.
Old 05-15-2013, 07:55 AM   #10
Was looking at some older posts on this account. Was this problem solved? If so, what was the fix?
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 12:00 PM
Another Dryer Question 3 to 4 wire John3rd Electrical 8 10-24-2011 06:54 PM
GE Spacemaker dryer won't shut off. scuzz1a Appliances 1 11-25-2009 08:06 AM
GE Dryer does not shut off in any mode brogrimm Appliances 4 01-30-2009 08:11 PM
Dryer doesn't shut off kiddo Appliances 3 01-24-2008 10:58 AM
