-   -   dryer will not shut off (http://www.diychatroom.com/f47/dryer-will-not-shut-off-163636/)
jerry1967 11-17-2012 10:00 AM
I have a kenmore dryer that will not shut off when the cloths are done. It just keeps going and the dryer and cloths get real hot. Does anybody have a idea what would cause this?
gregzoll 11-17-2012 10:22 AM
Timer is the first to check. Repairclinic.com is where I have gotten parts from for appliances in my house.
Last part was a handle for our Dishwasher, and even though I ordered it at 5:30 at night, got it next day.
boman47k 11-17-2012 08:56 PM
Running on timed cycle? The moisture sensor on mine is malfunctioning, so we just run it on the timed cycle. If not, it will just run and run.
If it does not stop when on timed cycle, I would suspect the timer or timer motor.
hardwareman 11-18-2012 03:23 PM
need to know what cycle you are using. Time dry, sensor dry or auto dry. If it is time dry then you have a bad timer, if sensor dry the you either have a bad sensor or a bad timer if auto dry then you either have a bad timer or possibly a restricted vent
jerry1967 11-23-2012 06:51 PM
I installed a new push to start switch, also a new timer but I still have the problem.
The dryer will not stop in the time dry, sensor dry or auto dry.
hardwareman 11-24-2012 05:11 PM
model# ?
jerry1967 11-24-2012 05:21 PM
Model# 11063932101
What does the power relay do?
hardwareman 11-26-2012 10:28 PM
does it have an electronic circuit board up by the timer?
hardwareman 11-26-2012 10:29 PM
Originally Posted by jerry1967 (Post 1059399)
Model# 11063932101
the relay is only used to send power to the heat element.
boman47k 05-15-2013 06:55 AM
Was looking at some older posts on this account. Was this problem solved? If so, what was the fix?
