-   -   dryer venting too short? (http://www.diychatroom.com/f47/dryer-venting-too-short-53609/)
Mike L 09-22-2009 10:15 PM
Is it possible for ducting to be too short for venting a dryer in a cold northern environment?
I plan on having a stacking dryer on an exterior wall....can I duct straight out the wall from the dryer?
Thanks for all the help.
Regards,
Mike
WaldenL 09-23-2009 12:19 AM
Can't be too short. If you can make a straight run out the wall that would be great!
VelvetFoot 09-23-2009 09:29 AM
I did that and it works great.
I put some insulation around the short run.
No coldness at all.
ARI001 09-23-2009 09:47 AM
Regards,
Mike
No. You must have a back draft damper (you can find these at any home center) at the end of the exhaust. You would then attach your dryer venting apparatus to the damper assembly. If you where planning on running flexible duct through the wall that is also a code violation.
With regards to the first question; the shorter and straighter the vent run the better for the dryer and the easier it is to periodically clean the exhaust vent line.
WaldenL 09-23-2009 10:54 AM
"End" meaning the part outside, yes? Wouldn't that be satisfied by the typical cap you put on the end of the pipe. I guess I was assuming the OP didn't just have a piece of metal tubing hanging out of a hole in the side of his house. :laughing:
ARI001 09-23-2009 11:34 AM
The damper is sold as a unit that you then would attach the ducting material from the dryer to the damper unit, the OP's post sounded as if the intent was to run the vent duct straight from the back of the dryer to outside the structure. I have seen this done by home owners in the past and to boot i have seen it done with flexi-duct run right through the wall to outside the structure and left hanging 2 or 3 inches from the ground. I have learned from experience to assume as little as possible.
Gary in WA 09-23-2009 02:28 PM
Good point, ARI001! Check with your local Building Department. Some cold areas require 12" above ground for snow....
Be safe, Gary
Mike L 09-23-2009 06:23 PM
I am assuming that you are refering to a standard dampered dryer vent cap on the outside of the house, which I think is obvious, but I guess you have seen it all and don't assume anything.
Can I use just regular smooth ducting like you would for your hvac system?
The other question is this main floor laundry stackables will be in a closet. Any ideas how I can hook up the vent and then put it in place as once the unit is in place there really isn't any access to the back for hook up.
Thanks for all the responses, I appreciate the help.
Mike
drtbk4ever 09-23-2009 06:26 PM
That is preferred over the flex duct. See Ari's post.
Good question. I'd like to hear some ideas on this too.
Scuba_Dave 09-23-2009 06:50 PM
If you are venting STRAIGHT out the wall I'd insert the pipe from the outside
Of course if this is the 2nd floor that might be tricky
OR put a longer pipe on, slowly push it back & thry the hole
-might need guidance from outside
then cut off the extra pipe from outside
OR a removeable long pipe attached to the exact size short pipe
Slide the unit in & then remove the longer pipe
VelvetFoot 09-23-2009 10:05 PM
I forgot how I did it, but I recall putting on an adapter kit for the dryer that diverted the exhaust 90 degrees.
I also remember the hole saw-it was just the right diameter and I think I went from the inside out after marking where the hole would go. There might have been a short section of the metallic flex-I'm not sure-I had farther to go than you did 'cause of the 90 degree turn. I did put some fiberglass insulation around the pipe. Maybe a piece of flex would work for you. It could stretch a little, you could put on the clamps, and then you could push the unit in place.
Gary in WA 09-24-2009 12:26 AM
A close quarter elbow, bottom of page: http://www.appliance411.com/faq/dryer-vent-length.shtml With this you might reach it from over the top?
Be safe, Gary
