Dryer Vent Too Long - Appliances - DIY Chatroom Home Improvement Forum
Old 09-23-2009, 01:31 AM   #1
dryer vent too long
the dryer vent is too long and the dryer is about 1 foot away from the wall. it looks pretty bad especially next to the washer which is flush against the wall. is there an easy fix?
pollybest is offline   Reply With Quote
Old 09-23-2009, 06:12 AM   #2
Remodeler
MinConst's Avatar
You can cut the vent shorter but it will always be 4-5" off the wall unless you have a inset built into the wall.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-23-2009, 06:44 AM   #3
General Contractor
www.dryerbox.com
You will find what you need there.
ARI001 is offline   Reply With Quote
Old 09-24-2009, 09:19 AM   #4
this is what i want to do, but i'm not sure how to. is it easy?
Old 09-24-2009, 03:10 PM   #5
Newbie Bill
Rewards Points: 522
Originally Posted by ARI001 View Post
www.dryerbox.com
I can see how this will help the OP with the dryer vent problem.
However, this is something I don't understand. We are told not to use flex duct for dryer vents, yet this apparatus is designed for use with flex duct.
Am I missing something or does the statement "Don't use flex duct" only apply in certain situations?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 09-24-2009, 03:40 PM   #6
WaldenL's Avatar
Rewards Points: 268
Never understood the "don't use flex" comment. I can understand that the majority of the run should be in smooth-wall, the parts in the walls and out the side of the house, but you need flex to install the damn thing, don't you? I mean unless you're a contortionist for Cirque du Soleil there's no way you're going to get a dryer hooked up w/out flex.
WaldenL is offline   Reply With Quote
Old 09-24-2009, 04:04 PM   #7
General Contractor
RE: Post #4 & 5
It is OK to run a short piece of flexi duct from the dryer to the wall (you may not exceed 8'). It is not OK to run flexi vent for the entire vent system. You also can not use screws in the vent ducts. You can reference Section M 1501 of the IRC building codes for more information.
Old 09-24-2009, 04:09 PM   #8
Newbie Bill
Rewards Points: 522
Mine is smooth the entire run, but you are absolutely correct about it being a royal pain in the .... to get hooked up. That is why I am curious about this.
Thanks for clarifying that Ari.
Bill
Old 09-24-2009, 05:08 PM   #9
WaldenL's Avatar
Rewards Points: 268
Wish the people that did my old install knew that. We've since moved the setup, but now that we're pulling the old system out as part of the kitchen remodel I'm finding flexi tube inside the walls.
Old 09-24-2009, 05:28 PM   #10
I've never had flex, here or at my last house
I use something like this, mine was oval w/round connection
So you could swivel it to the side
Method and cost to core a dryer vent in concrete? bgrimes Building & Construction 13 09-01-2009 07:54 AM
dryer vent through vinyl siding 7echo Remodeling 5 12-19-2008 08:07 PM
Dryer Exaust Vent ? yelladog Appliances 7 09-01-2008 09:03 PM
dryer vent insulation choppynuts Building & Construction 8 07-30-2008 08:02 PM
No Steam Vent for Dryer Bicycle Junkie Appliances 11 12-09-2007 03:58 PM
