Dryer Vent Solution - Appliances - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 07:35 PM   #1
Dryer vent solution
Please recommend a way to vent dryer over 20feet to help eliminate lint build up. Is flexible or solid pipe preferred?
CAMERON12 is offline   Reply With Quote
Old 01-30-2011, 07:42 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
you would want to use the rigid piping, minimun number of elbows you possibly can use. do not use screws at the joints, tape all joints with aluminum foil tape
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
CAMERON12 (01-30-2011)
Old 01-30-2011, 07:50 PM   #3
Rewards Points: 85
I'll second hardwareman's suggestion. I'd also plan for access in the rigid piping close to the dryer side. This way twice a year (when you change the clock) take a shop-vac and BLOW the piping clean to the outside.
rredogg is offline   Reply With Quote
The Following User Says Thank You to rredogg For This Useful Post:
Old 01-30-2011, 08:16 PM   #4
Registered User
Rewards Points: 5,516
Try to use 45's when you can so as not to impede the air-flow with 90's which catch more wet lint. Use a dryer duct brush with air for effective cleaning. Use a Type "A" hood for 50% more air flow; http://www.appliance411.com/faq/dryer-vent-length.shtml
http://www.hcpdc.com/pdf/Dryer%20Ven...quirements.pdf
http://docs.google.com/viewer?a=v&q=...up65cYgFwMvULw
Gary
Old 01-30-2011, 09:25 PM   #5
Rewards Points: 530
I was also going to mention a vent brush to get the vent cleaner.
Also think using 45's is a good tip for reason mentioned.
Dryer vent leaking imhotep Roofing/Siding 7 12-28-2011 03:54 PM
Dryer vent with 4" PVC pipe rjniles Appliances 30 07-01-2010 08:21 AM
attach bathroom fan vent to dryer vent hohadcr HVAC 9 03-08-2010 05:58 PM
Install dryer duct booster or find a shorter vent route? dinosaur1 Appliances 7 12-02-2009 12:26 AM
Help/moving dryer vent mjkpainting Plumbing 3 11-13-2008 08:44 AM
