Dryer Vent Replacement - Appliances - DIY Chatroom Home Improvement Forum
Old 07-21-2010, 02:28 PM   #1
Dryer Vent replacement
Hey guys, soo happy i found this site.
I pulled out my dryer to clean the dust behind the dryer and my dog ripped the vent hose pretty bad. its not salvageable,
Dryer is located in the basement with the hose going into the wall and up about 5 feet, How do i go about changing the hose thats inside the wall. Do i have to take the outside exhaust cover off?
I am going to try and add pics to help clarify what im talking about.
any ideas are greatly appreciated.
biggie12 is offline   Reply With Quote
Old 07-21-2010, 02:52 PM   #2
Handyman
Rewards Points: 512
Yep, pics woluld help a lot. That way we can suggest whatever fittings you will require.
canadaclub is offline   Reply With Quote
Old 07-21-2010, 03:52 PM   #3
i already cut a peice of the vent and took it with me to the store and bought a replacement hose they told me to go with the metal one.
Here is a few pics, taken from my phone so not the best quality
Dryer Vent replacement-img_0165.jpg   Dryer Vent replacement-img_0163.jpg   Dryer Vent replacement-img_0166.jpg
Old 07-21-2010, 05:26 PM   #4
need to do this today any suggestions
Old 07-21-2010, 06:28 PM   #5
The hose inside the wall raises 5' ?
I've never had the hose inside the wall
I've had the ones that go straight thru the wall
Then the hose attaches
Old 07-21-2010, 07:28 PM   #6
Registered User
Rewards Points: 4,924
What you bought is a transition hose, only to be used in the room. Once it goes into the wall, a rigid pipe and elbows are required. http://docs.google.com/viewer?a=v&q=...up65cYgFwMvULw
Either buy a though-the-wall termination duct hood/short pipe, or open up the wall and install rigid pipe.
You do need a new hood (Type A)to replace your broken one (Type B) and get 30% more opening at the self-closing door:
http://www.appliance411.com/faq/dryer-vent-length.shtml
In Dave's picture, the hood is legal for dryers but I don't recommend them. Look at the flapper doors pivot rods running across the pipe opening----- they trap the wet lint from getting outside.
Be safe, Gary
Old 07-22-2010, 05:26 AM   #7
Chicago, IL
Michael Thomas's Avatar
Be safe, Gary
BTW, there are some interesting changes re: dryer venting for the 2009 code cycle, see page 7 at www.northamptontownship.com/inc/documents/12/irc%20changes.pdf
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 07-22-2010, 03:03 PM   #8
Hey My new plan is to cut the dry wall and connect trnsition hose to where old one was and then back to dryer and replace drywall. I dont need to replace all the pipes for new ones.
Wouldn't that work okay wth just the hose i have now?
Be safe, Gary
Old 07-22-2010, 04:06 PM   #9
Household Handyman
Rewards Points: 1,408
"Wouldn't that work okay wth just the hose i have now?"
NO! PERIOD!
Do go to the trouble of removing only the dry wall where the current dryer hose is routed. Remove all remnants of old dryer hose, dryer vent on the outside, and start over, for safety reasons. DO use rigid aluminum duct inside the wall with 90 elbows at each end. These can be found at the apron stores and is cheap for what it will do as far as safety. Use the new "metal" flex hose, cut to fit, not wadded up nor kinked to do the connection from the dryer to the new duct, and the duct to the vent hood.
IMO-using the flex duct inside the wall is only asking for trouble down the road. Damp lint WILL hang up within the folds of this flex duct, building up until you only have a very small opening to blow the vented air through. Even with the set-up I/others recommend, with it running up, you will need to access it, say-annually for cleaning. David
Dryer vent problem carguy4sp General DIY Discussions 7 11-29-2010 09:26 AM
Dryer Vent type? cbzdel General DIY Discussions 6 06-08-2010 09:17 PM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 01:39 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 11:03 AM
