Dryer Vent Quandary - Appliances - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 09:20 PM   #1
Rewards Points: 150
Dryer vent quandary
Hi,
I have a quandary that I would like to get some opinion on.
I am finishing a basement project and will mean that the dryer will be on the inside and about 25" from the outside wall.
I plan to run the 4" pipe up (approximately 9ft) into the ceiling cavity to a 90 deg elbow, and then run toward the exterior wall mentioned.
What is your opinion about this method and approach?
Thank you in advance.
oodssoo is offline   Reply With Quote
Old 12-18-2012, 09:45 PM   #2
Rewards Points: 83
Use 45 degree elbows if you can. You will most likely need a dryer vent booster.
Always do the shortest run possible. Longer runs have the opportunity of clogging up and causing a fire.
Protocol. is offline   Reply With Quote
Old 12-18-2012, 09:47 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,834
Per the code in my area, the run can't be over 14' with 2 90's......
You need to look at the specs for your dryer....most will have the maximum limits on the run.
If your dryer manual says ok...then what your wanting to do sounds fine.
Here is a link with some additional info.
http://www.appliance411.com/faq/dryer-vent-length.shtml
Old 12-21-2012, 07:57 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
Originally Posted by oodssoo View Post
Hi,
it sounds perfect, I see no reason this would be a problem
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 12-21-2012, 08:29 PM   #5
Missouri Bound's Avatar
Consult your dryer's owners manual...it should tell you what you can do, according to the mfg. And there are always duct boosters made specifically for dryer vents.
Do you want it your way or the right way?
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 12:08 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 06:58 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 10:39 PM
Dryer Vent DoubleHumbucker Appliances 3 10-02-2009 01:50 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
