Dryer Vent Puzzle - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 04:00 PM   #16
I think this is the way to go. Anyone have a helpful link on how to cut through a wall? I mean, do I need anything besides a saw and courage?
NYCbianchi is offline   Reply With Quote
Old 05-24-2012, 05:46 PM   #17
Originally Posted by ktkelly View Post
Cut the drywall in the closet behind the unit, make your connection, then install this access panel cover so you can get to the connection in the future.
I think that's what I'm going to do. The closet is *next to* the unit, but I should be able to reach across and make the connection. Or climb in.
SOOO I've never cut through a wall before. What do I need besides an access panel and courage? A stud sensor, I suppose. What kind of saw?
Old 05-24-2012, 06:30 PM   #18
In a little over my head
Rewards Points: 706
Cutting drywall is easy. Look for a jab saw. They are cheap. It's got a pointy end. Just sorta drill into the wall with the pointy end, then saw. Be careful not to cut any pipes or wires.
A "multi purpose ocsillating tool" works great, too. If you're in the mood to buy a new power tool.
You may not need a stud sensor. There's gonna be a stud where the back wall of the alcove hits the closet wall. Just jab a little to the front. Once you're in the wall, studs are easy to find. ;^)
ratherbefishing is offline   Reply With Quote
Old 06-09-2012, 09:47 PM   #19
Thanks forum folks! I bought a jab saw and the access panel you recommended, cut through the wall (easy!) and connected the vent properly. A tiny bit awkward reaching through and connecting the hose but I think it's on there okay.
You guys rock!
Old 06-09-2012, 10:20 PM   #20
Missouri Bound's Avatar
Originally Posted by NYCbianchi View Post
connecting the hose
You didn't use a hose did you?
Do you want it your way or the right way?
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 01:08 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 07:58 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 11:39 PM
Dryer Vent DoubleHumbucker Appliances 3 10-02-2009 02:50 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
