Dryer Vent Problems - Small Space - Appliances - DIY Chatroom Home Improvement Forum
Old 10-24-2013, 11:49 AM   #1
First time posting here! Here's my story. In the laundry room to our new house, there was an old shower and the washer and dryer were non-stackable units on the other side of the room. I thought it would make sense to take down the shower, build a wall, and put stackable washer drying in that space....freeing up the rest of the space for more of a mudroom.
So here's my problem. The dryer vent hole to the outside is 2 ft above the floor. The vent on the dryer is 5 ft above the floor. I only left about 6 inches on each side, just enough to be able to access the plugs and water shut off valves.
I'd rather not have an access panel cut into the wall. How do I install the dryer vent? My best idea so far is to connect a pipe from the dryer vent hole going up, and a pipe from the dryer itself going up, connecting them with a U at the top (two ninety degrees put together). The I can access it if I climb over the top (see fancy diagram)
__
| O
O
Is there a better solution? I a dryer vent going up a problem (it'd be about 3 feet up, 5 back down, then out). I want to avoid using any flexible/crinkled pipe if I can. Its an electric dryer, FYI.
Thanks!!
moose8721 is offline   Reply With Quote
Old 10-24-2013, 12:30 PM   #2
Rewards Points: 14,278
http://www.sears.com/search=telescop...vent?seaxtel=1
jmon (10-25-2013)
Old 10-25-2013, 10:33 AM   #3
I kind of had a similar idea but with pipe, but didn't think it would work. How would I connect it? I would basically have to line it up perfect and push the dryer in, I don't think I could do it. I literally have just a few inches on each side.
Old 10-25-2013, 11:42 AM   #4
Rewards Points: 342
Small space like this. (see pic) Your idea would have the pipe going up 3 feet, looping 2 90's, then going back down 5 feet to a 90 and vent. IMO, not a very good solution if it can be avoided. I would try joe's idea first, as this is the most practical, economical and easiest solution to your problem. They do have the telescoping ones which are adjustable to different lenghts, etc. You won't know till you try.
If that won't work, is it possible to make a new vent so it alligns with the dryer vent and go straight out the wall and cap off the old vent? You would need just one piece of straight pipe, dryer vent, clamp and done. IMO, the shorter the run the better. Less chance of clogging and easier to clean, etc. Just a thought.
jmon is offline   Reply With Quote
Old 10-27-2013, 12:04 PM   #5
Rewards Points: 81
I have a dryer tucked into a small space over stairs. I made an access in the wall next to the dryer so that when we pull the dryer out it is easier to get the duct lined up correctly. (It takes two people - 1 to push, 1 to make sure it is connecting well.) then I used a very short telescoping piece as suggested above. (Mine is only 2 or 3 inches off horizontally, 1 or 2 vertically.) I took some pics for you. Dryer Vent Problems - Small Space-image-1040331073.jpg Dryer Vent Problems - Small Space-image-2490045201.jpg
I also used heat tape on all the joints of the duct as the particular duct I used had lots of air gaps.
MaineLL is offline   Reply With Quote
The Following User Says Thank You to MaineLL For This Useful Post:
jmon (10-27-2013)
Old 10-30-2013, 10:20 PM   #6
Rewards Points: 342
Nice job, glad everything worked out for you.
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 12:08 PM
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 04:48 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
moisture in dryer vent and door monkeygirl Electrical 13 01-10-2009 09:11 AM
