Dryer Vent And Pipe - Appliances - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 08:16 AM   #1
dryer vent and pipe
we just installed our dryer on the main floor of our house and i have noticed cool air coming in through the dryer and its vent. i need some ideas on how to solve this.
beckyhanson is offline   Reply With Quote
Old 10-26-2011, 08:49 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
Better door on it is all you can really do but you do not want to make the connection too tight as it will keep it from venting properly.
Keep your dryer door closed and seal up all the seam in the pipe.
I assure you that you home leaks plenty more air in other locations that can be fixed first.
Old 10-26-2011, 09:07 AM   #3
conenviro/hvacr
First make sure that the vent on the exterior of the house is in the right position (pointing down)check to be sure the flap inside the vent is completly closed when the dryer is off,if all of this checks out O.K then try tilting the exterior vent upward slightly sometimes something as small as a washer on the back edge of the vent(like a shim)will tilt it up enough to close the outdoor flap.where you said you just installed it cleaning should not be an issue but if you have used this vent in past instillations then make sure the vent is clear of anything that may be hold the flap open.
Good Luck
conenviro
conenviro is offline   Reply With Quote
Old 10-27-2011, 12:06 AM   #4
Registered User
Rewards Points: 526
As said already, check the hood termination door to see if it is closing all the way. If not already, install a one-flapper door (Type A, over a Type B), for 50% better air flow: http://www.appliance411.com/faq/dryer-vent-length.shtml
Gary
Dryer vent pipe, ok for insulation touch the pipe? quincy HVAC 3 10-26-2011 09:13 AM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
What is the best/proper method on affixing dryer duct mobiledynamics Appliances 2 09-19-2010 01:57 AM
Dryer vent with 4" PVC pipe rjniles Appliances 30 07-01-2010 08:21 AM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
