Dryer Vent Disk - Appliances - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 11:05 PM   #1
Dryer Vent disk
Could someone be so kind as to tell me what this disk is?
I was doing some preventative vacuuming out of my dryer vent and I accidentally sucked out this disk. For the life of me, I can't figure out how to properly fit it back into the duct. I can lodge it back in, but I really don't want to do that for fear of creating a blockage.
Any help or advice would be appreciated, especially advice on whether I need to bother putting this disk back in. This was in a vertical duct in a condo building.
shmevinator is offline   Reply With Quote
Old 02-20-2011, 12:46 PM   #2
Rewards Points: 6,652
It is to close the vent to keep outside cold & hot air from coming back in, when the dryer is not running.
Old 02-20-2011, 03:44 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
yeah you'll want to put that back in, go outside to where the vent terminates. You should be able to pop it back into the vent hood
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 02-20-2011, 07:21 PM   #4
So it's supposed fit in where the vent terminates? Because I found it in the duct right above my dryer and I'm on the 2nd floor of a 4 story building. Maybe it fell down? That would explain why I couldn't figure out where it fit in the duct.
Old 02-20-2011, 07:45 PM   #5
If maintenance can not figure where it came from, just go to Lowe's or Home Depot, or local Ace Hardware, and get one of the inline dampers that you can install in the Laundry room. If anything, something like that should have fallen out a long time ago, since the ears usually break after a year or so, because of not only the weight of the lint, but also because the oil dries out in the Plastic, and it becomes brittle because they are cheap.
Old 02-20-2011, 11:37 PM   #6
Registered User
Rewards Points: 526
As said, that is an in-line vent damper, probably against your current local Code:
M1502.3 Duct termination. Exhaust ducts shall terminate on the outside of the building. Exhaust duct terminations shall be in accordance with the dryer manufacturer's installation instructions. If the manufacturer's instructions do not specify a termination location, the exhaust duct shall terminate not less than 3 feet (914 mm) in any direction from openings into buildings. Exhaust duct terminations shall be equipped with a backdraft damper. Screens shall not be installed at the duct termination. From; http://publicecodes.citation.com/ico...002_par002.htm
Not an in-line, only on the termination hood.
M1502.4.2 Duct installation. Exhaust ducts shall be supported at 4 foot (1219 mm) intervals and secured in place. The insert end of the duct shall extend into the adjoining duct or fitting in the direction of airflow. Ducts shall not be joined with screws or similar fasteners that protrude into the inside of the duct. From; http://publicecodes.citation.com/ico...002_par005.htm
Bold is mine, you get the idea, nothing inside the smooth duct to catch wet lint..... Call your fire department or Building official to ask.
Gary
Dryer vent problem carguy4sp General DIY Discussions 7 11-29-2010 08:26 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 10:39 PM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 12:39 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 10:03 AM
