#1 |
dryer vent connection
I have a fairly new home.
The dryer and washer are upstairs in an interior closet. The installer had used a semi-rigid aluminum tube to connect the dryer to the wall vent pipe. The problem is that the semi-rigid aluminum tubes I can buy at Home Depot and Lowes (like the one on the right) fits the dryer end fine, but... .But at the wall vent pipe, it the semi-rigid tube's rigid end and the pipe are both 4" in size. The dryer end is the end you see in the bottom of the photo. The end that is to mate to the wall pipe is the end that has the ridges that is at the top of the photo. I have a heck of a time forcing the ridged end into the wall pipe. And I use a lot of aluminum foil tape to try to seal up that end well. Is there a better solution? I am at wits end, because alot of moisture builds up in the dryer. Last edited by ieee488; 11-04-2012 at 05:36 PM. |
#2 |
Get yourself a dryer vent connection kit.
#3 |
I have seen the dryer vent connection kit at the stores, but I am not sure exactly how they help. Can you explain?
#4 |
is this the kit you saw?
http://www.youtube.com/watch?v=QGHQbd4VdmE or you can do this http://www.youtube.com/watch?v=j0MKHKi9cmw |
#5 | |
dryer vent connectionQuote:
The second video at 1:29 is where I have problems with my current connection. That pipe end is the same size as that semi-rigid ducts I am finding in the stores. I don't know how much clearer I can be. It is that the sizes are not working out. |
#6 |
I use a pair of these to crimp whatever the hose is slipping over. It makes the OD smaller.
http://www.bing.com/images/search?q=...31A98ED41BE4A1 |
#7 | |
#1 HAWKEYE FAN
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"........... |
#8 |
Yes, I have those crimpers. They're part of my vast collection of tools I'll only ever use once.
#9 |
yes those will solve your problem...
#10 |
Just make sure you crimp on the right direction, otherwise you'll end up with a lint trap.
#11 |
where do you buy that dryer vent kit in the first video shown?
http://www.youtube.com/watch?v=QGHQbd4VdmE |
| Display Modes | |
| Another Dryer Question 3 to 4 wire | John3rd | Electrical | 8 | 10-24-2011 06:54 PM |
| Dryer vent problem | carguy4sp | General Discussion | 7 | 11-29-2010 09:26 AM |
| Dryer Vent Leaks Water | glennonr | General Discussion | 9 | 04-23-2010 08:50 AM |
| Dryer Vent | DoubleHumbucker | Appliances | 3 | 10-02-2009 02:50 PM |
| dryer vent connection woes! | dampwetbasementyuk! | Appliances | 1 | 09-27-2008 03:11 PM |
