Dryer Vent Codes - Appliances - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 06:33 PM   #1
Dryer vent codes
I live in a mobile home and our dryer vent, which is the plastic hose type, goes through the floor then makes a 90 degree turn and out the side of the house. I am looking at buying a new dryer and the salesman told me that the codes had changed and I have to use a solid pipe that can't go through the floor. He said it had to be vented directly to the outside wall. Is this true?
lindcb is offline   Reply With Quote
Old 09-22-2012, 07:48 PM   #2
Rewards Points: 472
how in the hell can it be vented on a outside wall if it is is we will say a bath room wall or a wall to a garage ?? i would talk to the code office and ask them. I wouldn't take his word for that.
del schisler is offline   Reply With Quote
Old 09-22-2012, 07:53 PM   #3
Rewards Points: 13,300
But I would still use soild pipe. DO not use rivits or screws to hold it together, use foil duct tape.
concretemasonry (09-22-2012)
Old 09-22-2012, 07:55 PM   #4
liscenced electrician
Rewards Points: 538
Sounds like crap to me. Considering I've only seen dryers by an outside wall about 10 percent of the time
jimmy21 is offline   Reply With Quote
Old 09-22-2012, 10:33 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
no such code, but do use solid pipe
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 09-23-2012, 12:09 AM   #6
Registered User
Rewards Points: 5,236
There is a code against flexible pipe leaving the room by way of floor or wall... though I have not heard of your situation.
Where are you located, I'll research it, or just call the local AHJ, as said already.
Mobiles need make-up air supplied, as opening a window twice the size of the pipe diameter and may need special exhaust system hardware. You cannot exhaust vent to a mobile home crawlspace, and the termination hood must be securely attached to the homes skirting.
Gary
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 01:08 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 07:58 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 11:39 PM
Dryer Vent DoubleHumbucker Appliances 3 10-02-2009 02:50 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
