-   -   Dryer vent codes (http://www.diychatroom.com/f47/dryer-vent-codes-157656/)
lindcb 09-22-2012 05:33 PM
Dryer vent codes
I live in a mobile home and our dryer vent, which is the plastic hose type, goes through the floor then makes a 90 degree turn and out the side of the house. I am looking at buying a new dryer and the salesman told me that the codes had changed and I have to use a solid pipe that can't go through the floor. He said it had to be vented directly to the outside wall. Is this true?
del schisler 09-22-2012 06:48 PM
how in the hell can it be vented on a outside wall if it is is we will say a bath room wall or a wall to a garage ?? i would talk to the code office and ask them. I wouldn't take his word for that.
joecaption 09-22-2012 06:53 PM
But I would still use soild pipe. DO not use rivits or screws to hold it together, use foil duct tape.
jimmy21 09-22-2012 06:55 PM
39 Attachment(s)
Sounds like crap to me. Considering I've only seen dryers by an outside wall about 10 percent of the time
hardwareman 09-22-2012 09:33 PM
no such code, but do use solid pipe
Gary in WA 09-22-2012 11:09 PM
There is a code against flexible pipe leaving the room by way of floor or wall... though I have not heard of your situation.
Where are you located, I'll research it, or just call the local AHJ, as said already.
Mobiles need make-up air supplied, as opening a window twice the size of the pipe diameter and may need special exhaust system hardware. You cannot exhaust vent to a mobile home crawlspace, and the termination hood must be securely attached to the homes skirting.
Gary
