Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-08-2013, 11:51 PM   #1
PhishPhix's Avatar
Dryer vent booster fan
Hi all,
My dryer vent makes 3 90 deg bends and travels about 20 ft. 8 of those feet are straight up. Of course my clothes take years to dry so I'm looking at installing a booster vent. I remember reading that if a certain set of conditions is met, than a booster should be installed. I can't seem to remember though if it was just a good idea or if it was code.
Any thought? Thanks.
PhishPhix is offline   Reply With Quote
Old 01-09-2013, 12:09 AM   #2
I'd be trying to figure out a better way to run the lines.
Old 01-09-2013, 07:24 AM   #3
I second what joecaption said. Dryers always work better if they are vented straight through the wall instead of through the roof. Have you ever cleaned your ductwork? The dryer? Duct fans work great, but aren't cheap, so you should first try to fix the problem another way.
Old 01-09-2013, 04:35 PM   #4
PhishPhix's Avatar
Dryer is in the basement on the wrong wall. The duct goes up to ground level than across to the outside. That only vents under the house. I have cleaned the vent, and the dryer it's self.
Old 01-09-2013, 06:14 PM   #5
I assume that your duct really is a hard duct and not the flexi-hose stuff. If it is the flexi-hose stuff, replacing it with hard duct will be a major improvement.
I'd also try to get the dryer on the right wall to reduce the duct run length. A booster fan is just another thing to clog up and break.
Thunder Chicken is offline   Reply With Quote
Old 01-09-2013, 06:17 PM   #6
Or cause a fire.
Old 01-09-2013, 11:35 PM   #7
JOATMON
ddawg16's Avatar
I agree with Joe and Thunder.....the booster just adds complexity and another point of failure.
Any way you can move the dryer? And....is the duct flex or hard? Makes a big difference.
For reference....when I was doing the design for our addition...in intentially moved the laundry room to the back next to an outside wall. My dryer vent is all of about 10" long. It's really neat....I just move the dryer into position...from the outside I can see the outlet of the dryer...I line up an insert the vent tube. I have enough wiggle room that it's easy. I have noticed that clothes dry a bit faster than they did when the dryer was in the old location in the kitchen.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 01-10-2013, 12:20 AM   #8
PhishPhix's Avatar
Ok, I feel like I need to specify this isn't my house, and I would never do this personally. The duct is 4" sewer PVC. I'm not comfortable with this personally, but is it a big enough deal to pressure the owner about?
Old 01-10-2013, 07:52 AM   #9
I don't know the temperature rating of PVC, but suspect it's not really suitable for a dryer vent.
Like ddawg16, when designing our log house I made sure the dryer would be on an outside wall. The vent pipe is less than a foot long.
In a previous house I owned, the dryer vent arrangement was similar to yours (but with one fewer elbows). I installed a booster fan and it helped immensely. Yes, they are one more thing that can fail, but in 6 years I never had any trouble with it. Fans are inherently very simple devices. About the only thing that could happen is the airflow switch sticking. I mounted the fan close to the wall so it could be easily be reached from outside for cleaning.
Old 01-10-2013, 08:55 AM   #10
#1 HAWKEYE FAN
hardwareman's Avatar
absolutely nothing wrong with adding a booster vent to your dryer. Many times homeowners have no choice in how the dryer gets vented. Booster fans are a safe and effective way to deal with long runs, install it and your dryer will live a lot longer life. As far as the PVC goes, it is no problem either.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-10-2013, 10:51 AM   #11
JOATMON
ddawg16's Avatar
PVC? I seem to recall somewhere that PVC was NOT to be used. I think it has to do with static electricity and lint getting stuck in it as well as the heat issue.
I believe the temp limit for PVC is 140 deg and a dryer vent can get hotter than that.
My
and
The Following User Says Thank You to ddawg16 For This Useful Post:
oh'mike (01-11-2013)
Old 01-10-2013, 01:53 PM   #12
#1 HAWKEYE FAN
link? any type of evidence with the electricity? Not doubting you I would just like to verify it as I see it done in apartment complexs very often.
as far as heat goes I can not see that as an issue.
Old 01-10-2013, 08:47 PM   #13
PhishPhix's Avatar
What booster did you use. I found one for $140 that is at a 90,, so that takes out one bend,, and the fan is out of the air flow so it shouldn't get as linty.
Old 01-10-2013, 09:34 PM   #14
JOATMON
ddawg16's Avatar
Here is a 'recent' thread in DIY on the subject....now I know where I got the impression that PVC was not ok....
Using 4" PVC for dryer vent
Basically the building code says it has to be metal....PVC is not metal...
My
and
Old 01-11-2013, 01:17 AM   #15
One would never want to use pvc for dryer vent code would not allow it for any reason. Read your owners manual of your dryer for venting intructions if that dont convince you I will post a dryer fire picture that may.
http://www.vcisafety.org/dryer_vent_fires.cfm
rkentzel is offline   Reply With Quote
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 01:08 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 07:58 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 11:39 PM
Dryer Vent DoubleHumbucker Appliances 3 10-02-2009 02:50 PM
Dryer vent ponch37300 General Discussion 10 01-21-2009 05:26 PM
