Dryer Vent In The Attic - Appliances - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 02:29 PM   #1
dryer vent in the attic
i have a contiuous clogging problem with 4 inch dryer vent. 10 feet vertical and 20 feet horizonal to the wall cap with most of this in the attic. someone recommended i increase the pipe to 5 inch, use 2 45degree elbows in place of a 90 and insulate the pipe with foil faced duct wrap. is this a good idea? will it be of any benefit?
laxdad is offline   Reply With Quote
Old 04-16-2011, 02:39 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Do you have some kind of booster fan on that? 10 feet seems long. It may be clogging as the air is not moving at a high enough pressure to push any lint away. Also this is solid pipe I hope?
Old 04-16-2011, 02:46 PM   #3
yes soild 28 gauge pipe, no booster fan. i cannot find any info on running this pipe in an attic good or bad.
Old 04-16-2011, 04:17 PM   #4
Ironlight's Avatar
Where does the clog form, how long does it take to build up, and what have you been doing to unclog it to date?
All three of those changes will help. If you live in a cold area then insulating the duct will definitely help. Right now, as the warm humid air goes along the duct in the cold attic moisture is condensing along the inside surface of the vent and catching lint. Bigger diameter and gentler bends will be less restrictive.
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
laxdad (04-16-2011)
Old 04-16-2011, 10:36 PM   #5
I am an a/c tech with 24 years. I understand the condensation issue. this problem is in my friends house. a Sears appliance guy told her it was too far of a run. i have found the heaviest lint clogging about half way down the pipe. i wanted to use a r-8 foil faced wrap on 5" pipe to insure minimum condensing. there is no other place to sidewall ventcap other than through the attic. the laundry room is next to the front door leading out to the garage. thanks for you time! - Bowie, Maryland
Old 04-17-2011, 03:17 PM   #6
Wire Chewer
Rewards Points: 126
Oh definitely need insulation on that pipe. I just assumed it would be insulated. That may or may not solve the clog issue, but it will solve potential issues that you may not even be aware are happening, such as condensation and water dripping. Maybe not enough to damage anything but over time it will.
And yeah I'd add a booster. Look at one that is designed to withstand decent heat. I find the centrifugal inline fans you see for bathrooms are very powerful, though not sure how good they would be in a heat application. I have one with a duct run that is a good 12 feet with bends all over and it makes the shower curtain move when I close the door as it's sucking air from the furnace vent as makup air. Very powerful units.
Old 04-18-2011, 07:26 AM   #7
So you have 40' of venting. but since most of it is a straight run only 2 90's. i think your problem, as was said, is due to moisture. is the hood closing? no screws connecting vent sections? attic ventilated properly?
Jacques is offline   Reply With Quote
Old 04-24-2011, 08:29 AM   #8
All ducting in unconditioned spaces has to be insulated. Residential driers have a max vent length of 25' including elbows so you're looking at installing a booster fan.
Dryer vent butterfly damper safe? TryHard Appliances 9 01-17-2011 02:44 AM
Dryer vent butterfly damper safe? TryHard Safety 0 01-14-2011 01:21 AM
Install dryer duct booster or find a shorter vent route? dinosaur1 Appliances 7 12-02-2009 12:26 AM
Dryer vent path Cossack HVAC 1 01-14-2009 08:57 PM
Building code violation fetzo Building & Construction 18 03-22-2008 02:42 PM
