Dryer Vent - Appliances - DIY Chatroom Home Improvement Forum
Old 10-13-2009, 10:24 AM   #1
Dryer Vent
I need to replace the outside cover of my dryer vent as the flap stay open. However, when i remove the screws on the outside and the cauk it the main tube doesn't come out. I can get the hood to turn but it looks like the pipe to inside is folded around the hood preventing the hood from coming out. And for some reason the pipe doens't move. I don't see anything from the inside that would obstruct the pipe from coming out. Any suggestions? I was thinking about possibly cutting the hood away from the pipe.
duffers is offline   Reply With Quote
Old 10-14-2009, 08:17 AM   #2
should just be a tight fit. if you buy another hood it comes attached to a piece of 4" tubing.
Jacques is offline   Reply With Quote
Old 10-14-2009, 08:26 AM   #3
so how do i get it out??
Old 10-14-2009, 09:42 AM   #4
Rewards Points: 6,652
Muscle power, and checking again on the other side to make sure disco from the piece you are trying to remove.
Old 10-15-2009, 04:41 PM   #5
Household Handyman
Rewards Points: 1,408
The older, thin sheet metal type dryer vents, and now the newer aluminum vents are made by inserting the tube-with small tabs made onto them, into the dryer vent hoods, then folding over the tabs to secure the two pieces together. You could be able to rotate the hood part and the tube part remain still. Some people-like myself like to put a ring of sealant around the tube before inserting to help seal the tube. This may be what you are encountering. IF you can rotate the hood/damper located on the outside, and there are no visible restrictions to the tube: it is time for "muscle power" as posted. Personally-I don't think you'll damage the exterior wall by pulling the tube out. Good Luck,David
Tags
dryer vent hood
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 01:39 PM
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 05:48 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 11:03 AM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
