Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-10-2012, 08:47 AM   #1
Dryer vent.
An I use PVC pipe for dryer vent? Will run about 8 foot Thinking it will be smoother less likely to clog with lint.
1954 remodel is offline   Reply With Quote
Old 05-10-2012, 08:57 AM   #2
Dryer vent.
Use galvinized stove pipe instead with foil tape on the joints, not screws.
If it's in a cold attic make sure to wrap it in insulation.
Old 05-10-2012, 09:52 AM   #3
Dryer vent.
It's running Under floor in crawl space to outside wall Will PVC not handle the heat? Removed slinky like plastic hose. It sagged and was full of lint in the low hanging spots.
Old 05-10-2012, 10:16 AM   #4
Dryer vent.
PVC will take the heat until there's a lint fire, then it melts and gives off toxic fumes.
Old 05-10-2012, 06:43 PM   #5
An old Tradesmen
Dryer vent.
Moved to Appliance forum.
Old 05-17-2012, 09:56 AM   #6
DIY or die !
Dryer vent.
I've honestly never seen a PVP vent hose.... probably for a reason. Creative idea though !
Use the Galvy solid vent 4''. It comes in sheets and you fold it to lock in place. BEST stuff IMO.
lewisthepilgrim is offline   Reply With Quote
Old 05-18-2012, 01:40 AM   #7
Moderator
Dryer vent.
Metal smooth wall pipe only, as per Code: http://www.codecheck.com/cc/ccimages...6th_Sample.pdf
http://www.hcpdc.com/pdf/Dryer%20Ven...quirements.pdf
Use a Type "A" termination hood for 50% more air-flow than "B": http://www.appliance411.com/faq/dryer-vent-length.shtml
Flex pipe (transition duct) is not allowed to be concealed (or under house), max. 8' and not thin-wall.
Gary
Clothes taking longer to dry?
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 08:55 PM
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 01:08 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 07:58 AM
Vent cap size ok for dryer? chazman113 Roofing 4 07-27-2010 11:39 PM
Dryer vent ponch37300 General Discussion 10 01-21-2009 05:26 PM
