Dryer Tries To Start But Doesnt - Appliances - DIY Chatroom Home Improvement Forum
Old 08-14-2013, 08:04 AM   #1
Dryer tries to start but doesnt
I recently replaced my frigidaire dryer motor. Now when i push. To start It makes a noise like it tries to start. But does not, almost like something is holding it back. Any ideas?
Redorchid is offline   Reply With Quote
Old 08-14-2013, 08:14 AM   #2
Gymschu's Avatar
Rewards Points: 180
Gonna need more info than that to give any type of educated guess. You may have to retrace what you did to insure that you installed the motor correctly. Was it the correct motor for your model? If not sized properly the motor could be in the way of the movement of the drum. I'm sure you had to remove the drum to replace the motor. Is it balanced on the rollers correctly? Is it too tight with the front panel? Just loads (pun intended) of potential problems could be causing this and without pics of what you did or knowledge of the process you used, well, we're just taking shots in the dark.
Old 08-14-2013, 08:29 AM   #3
Yes i had to take the drum off. Yes it is the correct motor for. My dryer and yes it is installed correctly. It at least makes a sound now.... Didnt before. Sounds like its starting then quickly shuts down
Old 08-20-2013, 11:50 AM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
does it have the quick disconnect if so it probably has a loose connection inside the connector, it happens. If its not the connector then you probably got a bad motor
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 02:10 PM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 11:35 AM
Dryer Venting Question cbzdel HVAC 4 05-18-2011 03:16 PM
Dryer exhaust damaging laminate floor? snowkilts Flooring 1 03-31-2011 09:15 PM
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 07:18 PM
