Dryer Timer Running Backwards And Too Hot - Appliances - DIY Chatroom Home Improvement Forum
Old 03-24-2009, 04:03 PM   #1
Dryer timer running backwards and too hot
Whirlpool dryer model LEP6848AWO timer starts going in the right direction, then timer starts going backwards. It will eventually turn itself off, but the clothes seem to be very, very hot (no burning smell) even on low heat setting. This started with the automatic dry setting, and now seems to happen on the timed setting too. I took the back off and cleaned out the vent and pipe is clear. Problem is intermittent. Do I need a new timer? Cycling thermostat? New dryer?
pattyl is offline   Reply With Quote
Old 03-24-2009, 04:11 PM   #2
Are you saying the timer is running down and then starts adding minutes?
What happens in auto cycle
Chemist1961 is offline   Reply With Quote
