Dryer Timer Clicking - Appliances - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 08:08 PM   #1
Dryer timer clicking
I have a 13 year old Kenmore stackable unit; model 417.99680210
I have done a number of repairs on it over the years and really don't want to give up now...
this past weekend, the dryer stopped working- drum wouldn't turn. I thought it was the dryer start switch and replaced that. Still won't start.
Instead, when I have the door shut, and turn the start switch, the dryer timer makes a clicking sound. I assume this is the mechanism trying to work.
I don't see any openings on the timer, where lint could have come in and clogged things (the washer controls suffered that fate two years ago, but I was able to clean and rebuild them). When I went to a local repair shop, they suggested I check the thermal fuse. Problem is, I can't find it. I could pull the drum and look, but I don't see anywhere on the back of the dryer where mounting screws would be. I also checked online at Sears for schematic drawings, and again, I don't see any thermal fuse.
If the dryer timer is getting power and clicking, that tells me the start switch works.
But before dropping almost $100 on a new timer switch, I'm looking for other ideas. I already spent $50 this week on the start switch (overnighted) to no avail.
Any ideas are greatly welcomed.
Troglodad is offline   Reply With Quote
Old 01-20-2011, 02:26 PM   #2
Update: After a bunch of googling, and lots of suggestions, it finally turned out to be the thermal fuse, hidden behind the dryer drum, on the lefthand side of the dryer, near where the power goes into the heating coils. Major pain in the ass to repair (suggestion: Access Panel), but so far it seems to be working.
dryer timer 7echo Appliances 0 09-10-2010 07:20 AM
Dryer timer running backwards and too hot pattyl Appliances 1 03-24-2009 03:11 PM
dryer timer brocken JAVAMAN Appliances 3 09-11-2008 10:29 PM
Dryer timer billmac Appliances 1 06-22-2008 10:56 PM
dryer timer auto cycles don't work mikedudl Appliances 6 04-29-2008 07:48 PM
