Dryer Repair - Appliances - DIY Chatroom Home Improvement Forum
Old 11-16-2013, 12:44 PM   #1
My Kenmore electric dryer runs buts does not heat. The element and all the safeties are fine. It is getting full voltage. Where do I go from here?
Depotdaddy511 is offline   Reply With Quote
Old 11-16-2013, 01:10 PM   #2
PoleCat's Avatar
Rewards Points: 1,646
Post a picture of the schematic if you can find it.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-16-2013, 02:54 PM   #3
Here it is. From why a you tube video tells me I think it may be the timer but hell I don't know.
Old 11-16-2013, 02:55 PM   #4
Rewards Points: 6,652
What is the make & model of the unit? Do you have a All-in-one printer, that you can scan the schematic in, then post the picture from it. What did you do to measure the circuit out, to check for proper resistance and voltage (make & model of meter, or tool).
Also if it was the timer, the unit would not run at all, or if it did, it would stop within a very short period.
Old 11-16-2013, 03:09 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,458
See at the bottom where it says "5400W Heater"? Put your voltmeter across there....if your getting 240 Vac....and no heat....your heater is shot.
If your not getting 240Vac....start tracing back.
BTW....are you sure that the dial is not on No Heat?
Old 11-29-2013, 06:01 PM   #6
In a little over my head
Rewards Points: 706
You sure it's getting 220V and not just 110? The motor's 110/120, but the element is 220. Check both phases.
ratherbefishing is offline   Reply With Quote
Old 11-29-2013, 06:16 PM   #7
Gymschu's Avatar
Rewards Points: 668
Hopefully, you have breakers and not fuses. When I had fuses, my dryer would run, but not heat when a fuse blew. Just something to check if you have an old fuse box.
Old 11-30-2013, 07:01 AM   #8
PoleCat's Avatar
I had a Pushmatic breaker fail on one leg and not the other. The smell it made when it fried was so much like that of a dead mouse that I never considered that there was no mouse involved until I had the dryer in pieces all over the basement. On a positive note I cleaned up the internals as good as new.
The Following User Says Thank You to PoleCat For This Useful Post:
Gymschu (12-01-2013)
Old 11-30-2013, 07:36 AM   #9
PoleCat's Avatar
Everything in the heater branch is between the two red arrows. With the dryer unplugged and those two points disconnected from the rest of the system you should have a very low resistance reading which you take with an ohmeter and one probe at each location.Dryer Repair-dryer.jpg
Dryer exhaust damaging laminate floor? snowkilts Flooring 1 03-31-2011 08:15 PM
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 06:18 PM
Electric Dryer repair assistance aggreX Appliances 11 05-23-2010 04:22 PM
dryer repair teras Electrical 1 09-10-2009 07:10 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
