Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 06-01-2011, 11:12 PM   #1
Dryer Panel wont come off
I have a new whirlpool cabrio gas dryer and I need to run the vent through the side. It has the knock-out panel and I was assuming I needed to remove the back panel in order to run the ductwork out the side.
Problem is..I can not for the life of me get the back panel off. I have removed all the screws..the top control panel is loose but the back panel still wont budge. Any ideas? Anyone done this with out whirlpools "special" kit ? I figured it would only need a 90 degree elbow and some hose clamps.
Rotate is offline   Reply With Quote
Old 06-02-2011, 08:46 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
the back is not going to come off, you need to take the front off. Remove the bulk head, remove the belt, remove the drum, now you can do what you need to do.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 06-02-2011, 09:47 AM   #3
Thanks hardware man, ill try from the front this evening.
Old 06-13-2011, 01:37 PM   #4
Well, I went through the front and was able to get the piping out the knock-out panel. Getting the knock-out panel out was the hardest part! There was nothing knock-out about it.
You should have seen the look on my wifes face when she came home tp see her new dryer taken down to the bare bones! Its working fine know though, thanks for the help!
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 09:00 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Connect 120/240 clothes dryer to 3-phase panel - possible? Gamm Electrical 14 09-10-2008 10:38 PM
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 07:28 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
