Dryer Noise - Appliances - DIY Chatroom Home Improvement Forum
Old 01-25-2014, 07:47 AM   #1
Dryer noise
When using my dryer- it is making various noises....sometimes loud, sometimes just an intermittent squeak. Right now I am hearing what sounds like money or other 'pocket finds" rattling around in it(there is not any) and a repetitive squeak. The heat is working- but annoying sound! What can/should I do?
djods65 is offline   Reply With Quote
Old 01-25-2014, 07:55 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
Most dryers have nylon bearings at the front side. Its just a shoe of plastic that the drum rides on. When they get worn out the noise can get pretty bad.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 01-25-2014, 08:06 AM   #3
Rewards Points: 13,300
Could be a lot of things.
Worn belt.
Bad pulleys.
Something stuck between the drum and the front panel.
Got a model number?
Old 01-25-2014, 08:06 AM   #4
Is it ok to use the dryer even though it is making these noises?
Old 01-25-2014, 08:39 AM   #5
PoleCat's Avatar
I wouldn't for very long.
Old 01-25-2014, 08:39 AM   #6
Model - general electric - drsr495eg0ww
Old 01-25-2014, 08:41 AM   #7
Now it is running and making no noises at all- heat is still working...?????
Old 01-25-2014, 08:49 AM   #8
PoleCat's Avatar
Like Joe said, it may have been something stuck between the drum and the face and it has fallen out. I used to clean out a couple dozen dryers twice a year at a retirement community and I usually came out a couple of bucks ahead from change removed from the fan housing.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 02:10 PM
GE dryer noise gfelton Appliances 2 07-09-2012 05:43 PM
GE Gas Dryer Rattling Noise Jeff Barron Appliances 1 01-05-2012 07:19 AM
GE Gas Dryer making rattling noise Jeff Barron Appliances 4 12-06-2011 07:47 AM
Dryer making a whining noise wendyknight General DIY Discussions 3 01-05-2010 01:46 AM
