Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-18-2007, 12:16 AM   #1
Dryer Moisture
Hello gang,
I was wondering if someone could help me with my dryer problem. It will dry clothes, but it take 3 full cycles to do so. There is a heave build up of moister in the front panel just past the lint trap.
Any idea?
Blueprint is offline   Reply With Quote
Old 08-18-2007, 07:47 AM   #2
FatAugie's Avatar
Dryer Moisture
Is the exhaust vent clear? When you're drying clothes, have you checked outside to make sure the exhaust is flowing strong?
FatAugie is offline   Reply With Quote
Old 08-18-2007, 09:55 AM   #3
Darylh's Avatar
Dryer Moisture
Originally Posted by Blueprint View Post
Hello gang,
Any idea?
You need to clean the dryer and vent pipe, that is why you have a build up of moisture.
Darylh is offline   Reply With Quote
Old 08-20-2007, 07:47 PM   #4
Dryer Moisture
I'll try the vent from the outside. Thats the only thing I havent tried yet. I'll give it a shot Tue and let you guys know. Thanks for the responces.
Old 08-21-2007, 03:40 PM   #5
Dryer Moisture
Check your flex exhaust duct. Sometimes it sags and creates a trap similar to a p-trap in your drain lines. The moist air condenses and collects in the lower portion of this inadvertent trap and eventually blocks air flow so that the drying process is slowed or blocked entirely. This can happen also in a metal dryer exhaust duct under the house if it is allowed to sag.
yudamann is offline   Reply With Quote
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 05:33 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
Problem with ELECTRIC DRYER plugs SpaceCrawler Appliances 6 06-03-2007 11:21 AM
To Moisture Barrier or Not to Moisture Barrier? cordon Flooring 7 05-22-2007 10:48 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
