-   -   Dryer Moisture (http://www.diychatroom.com/f47/dryer-moisture-10815/)
Blueprint 08-17-2007 11:16 PM
Dryer Moisture
Hello gang,
I was wondering if someone could help me with my dryer problem. It will dry clothes, but it take 3 full cycles to do so. There is a heave build up of moister in the front panel just past the lint trap.
Any idea?
FatAugie 08-18-2007 06:47 AM
Is the exhaust vent clear? When you're drying clothes, have you checked outside to make sure the exhaust is flowing strong?
Darylh 08-18-2007 08:55 AM
Originally Posted by Blueprint (Post 58276)
Hello gang,
Any idea?
You need to clean the dryer and vent pipe, that is why you have a build up of moisture.
Blueprint 08-20-2007 06:47 PM
I'll try the vent from the outside. Thats the only thing I havent tried yet. I'll give it a shot Tue and let you guys know. Thanks for the responces.
yudamann 08-21-2007 02:40 PM
Check your flex exhaust duct. Sometimes it sags and creates a trap similar to a p-trap in your drain lines. The moist air condenses and collects in the lower portion of this inadvertent trap and eventually blocks air flow so that the drying process is slowed or blocked entirely. This can happen also in a metal dryer exhaust duct under the house if it is allowed to sag.
