Dryer Making LOUD Noises - Appliances - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 08:34 PM   #1
Dryer making LOUD noises
My Frigidaire Gas Dryer is making very loud noise when drying, almost like the hub inside is off balance. Do you have any suggestions what it would take to fix this?
gusfamily07 is offline   Reply With Quote
Old 06-29-2011, 09:22 PM   #2
firehawkmph's Avatar
Rewards Points: 1,884
Gus,
just guessing without hearing or seeing it. One source of noise is the spring loaded idler pulley the belt runs around. If the shaft the pulley rides on doesn't have any lubrication and it runs dry, it may gall a bit causing the pulley to intermittenly bind and turn. When it binds, it changes the tension on the belt, which causes the idler assembly to pitch back and forth, causing a loud banging noise. To fix, take the pulley off and check the shaft for any galling. Take some fine emery cloth and get rid of any burrs and polish up the shaft where the pulley rides. Check the hole in the pulley for any burrs, sand lightly if there are until smooth. Put a very small amount of high temp grease on the shaft where the pulley rides. Just a thin film is all you want. Shaft should turn smoothly without any binding. Re-assemble and the noise should be gone.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 06-29-2011, 09:54 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
Frigidaire dryers are noted for bad rear bearings. Put new bearing in and all will be well.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
GE Dryer making a rattling noise KRB1460 Appliances 3 02-03-2011 09:56 PM
Dryer making loud buzzing sound awoo23 Appliances 2 03-30-2010 09:20 PM
Dryer making a whining noise wendyknight General DIY Discussions 3 01-05-2010 12:46 AM
GE Dryer making loud scraping noise mcates Appliances 4 03-05-2008 02:05 PM
New house, freezing temps, loud popping noises lp61006 Building & Construction 11 02-22-2008 05:36 PM
